1 - 8 of 8 Posts
Hey guys whats up!! It been raining all day today. I went inside my car in notice water on my floor board. Does any one know where it could be coming from??? I know it not coming from the door. Got any ideas?
Discussion Starter · #2 ·
Might want to check the gasket around your windshield, espicially at the top. That's where I had my problem.
Max
95 SE-R
also your ac evaporator or heater core putting off some condensation and/or water getting cycled out of your a/c system and your drain tube is clogged. check it out, probably not a problem though. check to see if the water is hot or cold, and you will find your problem
98 se-r w/ p/r cai, stillen header, courtesy exhaust, JUN flywheel, ACT clutch, NOS nitrous kit, eibach springs, kyb struts, st sways, cusco camber plates, f/r strut braces, lotsa bushings, and a bunch of other crap not really worth mentioning
it only happen when its raining outside. My seal on my wind shild looks ok. got any more ideas? One more thing i forgot its a 94 SE-R
TurboSentra
may be some kind of seal around your door also.
What seal are you taking about around the door???
TurboSentra
SR20DET Power, HKS EVC EZ(not installed), HKS TURBO TIMER(not installed), JWT ECU , Greddy catback exhaust, 3 in ATR Race Cat, 3 in downpipe, HKS plugs,Magnecor wires, Rota rims 17x7.5
AGX'S struts and Ground Controls waiting to be put on
My sister's old Escort would leak when it rained too. The best way to find where its leaking is to get a hose and place it on whichever side is leaking. Turn it on, and watch for the water. You have to let it run, spraying the water will not show the leaks.
Eric Waterman
1996 200SX SE-R
1997 200SX SE-R
1991 Sentra SE-R
if you do not have a seal around your door, thats the problem. the whole door has a seal, except for the bottom sill.....
1 - 8 of 8 Posts
