Hey gang, I have an Autometer Water Temp gauge and it came with 2 NPT sender fittings for the engine and its own sender. The sender fittings didnt seem like they were the same size as the factory one so I just wired it up to the factory sender and its normal temp is 195. Is this going to screw readings up for REAL readings or is the factory sender a close enough match to Autometers' sender? Does anyone know what the normal operating temp is of the SR20? TIA!
For those of you that are going to ask, and I know you are out there, why I installed another temp gauge, well I had an extra hole in my 3 gauge A-pillar after selling the NOS gauge with the kit. I am going turbo very soon so I will add the BOOST gauge then. Yes, I know I already have a boost gauge too. DAMNIT I JUST WANTED IT! :D J/K.
Team Tool
I did this too. When i hooked up the wires to the factory sender the radiator fans kept running non stop. So what i did is have the exiting(off front passinger side of motor) radaitor hose fitting tapped for the sensor. Now my normal temp. is 180 deg.
Cool, soyou tapped the radiator inlet or the fitting on the engine itself? Thanks for the help!
I have seen the light! Thanks gang! Looks like I have a project tp do when I get home form work! :D
