Well, I finally figured out why the car wouldn't start, Im not sure what I was thinking (or drinking), but I had shimmed the intake valves wrong so it was leaving the valves open. I tested it and ran it a few miles and it was running great I even went into boost (~9 psi) and I had forgotten how fast this thing was. But then on my full throttle attempt when I shifted out of 1st to 2nd it made a horrific gear grinding noise (that noise that no one ever wants to hear) so I pulled over and pulled the VC to find all the intake rockers scatterted and it was apparent that the valves were bent again.
So, Im back to pulling the motor apart and seeing what happened. At TDC both cam gears were 4 teeth off, so I think the crank sprocket and rails are my culprit, if any body has ideas on what I should change while im pulling all that apart they would be really appreciated.
I also need to thank Eric W. for helping me out again by emailing me the FSM pages to set the timing, Lawrence for mentioning to check the shims, Mike-"Audiboy" for giving me some answers on some DET specifics, as well as everbody who responded to the last post.
Andy
93 NX2K
some stuff and a DET
"project street mod?"
1988 BMW M3 w/ a few toys
Andy
93 NX2K
