depending on how much hp you want..... manifold, turbo, injectors, maf, fuel pump, engine managment, IC, oil lines, maybe water lines, couplings, lots and lots of fittings and clamps, IC pipes, BOV, vacuum lines, some teflon tape, anti-seize, higher heat range plugs, downpipe, gaskets, clutch, brakes, exhaust, motor mounts, air filter and intake tube, gauges if you want, drill and tap the block for the oil drain, get a fitting for the block, maybe a fuel pressure regulator, I think that covers most of it.
might want to read up some on
www.se-r.net and do a google search
