from serching it seems like you guys are using 300zx twin turbo O2 on your sr20det bluebird engines. can any one confirm that.
i need to know what year zx? and is there difference between size of O2 on your u12 and u13 sr20det. mine is u12
If you are running the bluebird ECU, then get an o2 sensor from a '89 Z32 300ZX turbo. This is a 3 wire o2 sensor with red, black, and white wires.
If you want, I can get that o2 sensor for $80 shipped to you with my discount.
Audio Nut
As stated, go the 89 turbo 300z o2 sensor, that's what I was running with the U12 ecu and still am running.
Don't mean to hijack here... I am curious though, when you swap over to the JWT ecu, are we supposed to use the USDM Sentra SE-R o2 sensor?
-Travis G.
-Travis G.
If JWT re-programs your bluebird ECU, then you keep the 300ZX o2 sensor.
If they re-program a B13 ECU, then you need the USDM o2 sensor. You will also need the USDM TPS and coolant sensor, too....IIRC.
