Indeed, indeed. Definitely a whole lot of reading. Plus, that list that you make keeps getting longer and more expensive once you start piecing together stuff. It was fun putting together the list at first, but now I dread each new item I add because that final amount keeps going upFirst things first, read, read, read, and read some more. Read until you're blue in the face.
Then once you're blue, research some more.
After that, you can come up with a methodical solution, as to what power you want, and from there you can piece together your wishlist.
Then spend money buying parts.Make that list and check it 20 times. You can and likely will leave something seemingly insignificant, yet very important to the build off of that list.
Then and only then, once you have done all of the above steps, should you even consider starting your build.
Oh, and visit the turbo faq area, and the technical information library, etc. etc. etc. There's TONS of information on here.
Welcome to the forums.
:rofl: You too?! Damn man all I wanted was a T25 kit to play with, and now I've got an ECU off at Calum for the realtime, BC ST2 Cams with S/R, and all other kinds of crap. Now I'm looking at a T28 with a nice mani and ext. w/g, and I haven't installed a single part yet! :rofl: :eek2:Indeed, indeed. Definitely a whole lot of reading. Plus, that list that you make keeps getting longer and more expensive once you start piecing together stuff. It was fun putting together the list at first, but now I dread each new item I add because that final amount keeps going upIt should be worth it in the end.
X 2.First things first, read, read, read, and read some more. Read until you're blue in the face.
All I wanted was a simple GTi-R swap. Then the list just kept growing. And it is still growing. Some times it makes me sad, but then I just remember the wornderful DET I have, and I am smiling in no time.:rofl: You too?! Damn man all I wanted was a T25 kit to play with, and now I've got an ECU off at Calum for the realtime, BC ST2 Cams with S/R, and all other kinds of crap. Now I'm looking at a T28 with a nice mani and ext. w/g, and I haven't installed a single part yet! :rofl: :eek2:
