intake cam and header wouls most likely be a great combo. if you buy both used (or buy a cheap header ie: pacesetter or obx/stone racing both run approx 150 bucks)98SERwTricks said:I'd get a 91-93 Intake cam and find a Stillen 4-1 header cheap in the classifieds - you'll have a great powerband for fun times![]()
jdrobert said:I have a popcharger, exhuast and thinking about header next. would should i do after that for good power gains.. money is a issue.. thanks
Daniel Roberts
ThanksStorm88000 said:Just like everyone else said, the 91 cam. Buy from SE-Rawkus, he is a great seller.
I put one in last weekend and can't believe what a power difference it makes.![]()
i like how so many people on this forum say this, it's not free if you don't have a timing light lying around your house. Plan on spending at least $30 bucks for a decent timing light. At least you won't have to depend on a shop to adjust your timing for $50+ when you finally know how to do it yourselfsr20andafalcon said:bump timing to 17 degrees 5 whp for free.
worldcrafter said:i like how so many people on this forum say this, it's not free if you don't have a timing light lying around your house. Plan on spending at least $30 bucks for a decent timing light. At least you won't have to depend on a shop to adjust your timing for $50+ when you finally know how to do it yourself
worldcrafter said:At least you won't have to depend on a shop to adjust your timing for $50+ when you finally know how to do it yourself
no, I just bought a tune-up kit at a local auto store and did it myself. I've never used a timing light prior to adjusting my timing, so that goes to say that it is easy to do it. I'd expect shops to charge at least that much for timing adjustment, since ignition timing would probably be the most important tune-up step that a shop could do for you.Storm88000 said:Did you seriously pay $50 for that?Adjusting the timing is so easy.
I was just going to say the same thing.TeamPCI said:5 whp from timing? I didnt feel much of a differance at all....I doubt we could make 5 whp from bumping it to 17....
Other than that, your plan sounds the best. The 5 whp just sounds a bit high....
