Hi Guys
Need some help down here!
Im on a budget ok. I can only afford one of the two.
What is the best thing for me to do??
Replace my stock turbo (SR20DET) Roller bearing T03 or GT30 using stock ecu and intercooler?
Or get an Aftermarket computer EMS using TURBO and intercooler??
Which of the two should be a good gain in HP and safe on the engine??
Or should I just get a Larger intercooler using stock turbo and stock ECU>????
Thanks
96 all motor SeR said:
I would go with a larger front mounted intercooler. Seems safest to do. If you do any of the others you would want to upgrade the ecu, injectors, and turbo all at once to be safe. That my opinion. [/QUOTe
Thanks!
Would i have to change the Intercooler piping when I get the Larger turbo??
