1 - 8 of 8 Posts
I have a huge problem with wheel hop when I want to get a goog launch! Is it the way I am launching(not doing it correctly) or is there something I can get? And will inserts help, if so which ones? Thanx in advance and I have searched.
rollin 4 deep with JoeD
^^^ BS!! I've tried it all, solid motor mounts, control arm bushings, etc... The only thing to solve your wheel hop problem at the track (this is the only place where you launch that hard right?) is to get slicks!
damn.. touchy subject for you? im just saying this took care of my problem.
your car will drive much smoother under high throttle with solid mounts and control arm bushings.. it may not take car of the complete issue but it will help A Lot
I think that its a combination of tire/mounts. I used to have mad wheel hop when I had those cheap Tiger paws. I installed the ES instert (front&back) and some Michelin Pilot tires and the hop was gone ! Hope this helps.
1 - 8 of 8 Posts
