1 - 12 of 12 Posts
Egg Lover
Can anyone tell me which wire is for the Throttle Position Sensor. Also when I look at the timing pulley I see 4 small marks very close together. Right now the index is pointing to the mark closest to the firewall with the TPS connected. That seems to say that the timing is very much retarded. Will disconnecting the TPS change that? It seems that I should be shooting for the second mark from the front of the car. Is this correct. Thanks.
Off-Topic lurker..
right above the throttle body, 3 prong sensor i do believe...but...i am ****ed up so i dont know if that's where it is..hehe..
Aztec Red 1993 NX2000
Start your car, let it warm up. Stop your car, unplug your TPS (right next to your throttle-body). start your car, rev it to 3000rpm three times, get a buddy to hold it at idle, time your car. IIRC the last mark, closest to the front of the car is 20 degrees, position your timing mark between the second to last, and the last mark closest to the front of your car (~17 degrees). Stop your car, reconect TPS, should be good to go. Sometimes it is neccesary to reset your ECU by unplugging the NEG. battery cable for an hour or so.
Hope that helps,
Tait
<font face="Verdana, Arial" size="2">get a buddy to hold it at idle, time your car.</font>
The car should hold an idle with the TPS disconnected. If it doesn't, then the idle needs to be adjusted.
<font face="Verdana, Arial" size="2">Sometimes it is neccesary to reset your ECU by unplugging the NEG. battery cable for an hour or so.</font>
Disconnecting the battery for an hour won't reset the ECU. You'll need to leave it disconnected for at least 24 hours.
Here's a link that explains how to adjust your timing:
http://www.sr20de.net/engine/about_timing.html
Thomas Fox
'93 NX2000
www.geocities.com/subcltr_nx2000/Homepage.html
Egg Lover
From Nick's picture it would appear that the plugs to disconnect are #2. That area has a wire that goes to what I presume is the TPS that splits off into 2 connectors. Do I have to disconnect both? Thanks.
Stuck on an island
that is for the avi ? cant remember the proper name for it at the moment, but a hose used to run to the stock air box to were that filter is i have a pop charger in place of my oe filter
1 - 12 of 12 Posts
