If you email me I can have Andreas Miko make you one. Or I can just put you in touch with him. One of the main differences is that the CAI from Place is made of ceramic coated steel if I am not mistaken. We made mine from aluminum. I will try and post some pics when I get home. I could be wrong about the CAI from Place being made from steel, someone please correct me if I am wrong. Nevertheless it is an excellent upgrade and the people at TPR offer very prompt service. I had it in my car at first and later switched to Andreas custom intake. I will note that we switched only as an experiment and I was very happy with both of them. One advantage of the aluminum is that it tends not to get "heat soaked" in stop and go traffic. Either way you will have to do a little cutting and the Place intake provides you with pretty detailed instructions on installation. Hope this helps!
98 200SX SE-R custom cold air by Andreas, AEBS header, Greedy exhaust, JWT motor mounts, UR pullies, Nismo fuel press.reg, JWT C1 cams and JWT gears, Valve springs and titanium retainers, ACT HD/PP, Clutchmasters flywheel,Sprint spring/AGX combo, no cat, custom JWT computer w/cam program, Bored airflow meter, and a best ET of 14.78 @94.8mph on street tires with full interior and no limited slip diff!
