1 - 10 of 10 Posts
Whisky Tango Foxtrot
What is the correct wire to tap for a rpm signal? I don't think my factory tach is going to be accurate enough at 8k :D
This one should.
They're just cones!
Where did you decide to put that bad boy? You better post a picture when you get it in. Wait- You're going to be able to rev to 8k?!?!? I want some of those fancy springs and retainers...
I am thinking righ in front of the Center airvent. I really don't want it on my dash. The C2 ecu is set for 7950rpms that's the highest the ecu will read properly.
Low flying black object
Green wire off the distributor connector
1 - 10 of 10 Posts
