I agree that is a great price for white guages, I happened to find one on the classified ads on SE-R.net for 90bucks
never used. I have a 97 with the security light in the tach guage so I had to drill a hole for that (turned out good). they were a bit of a pain to put in. My tip to you that if u do install them is that before u put back ur tach and speedo needles back on, hook up ur cluster up, turn the car on and then turn it off and put ur tach and speedo needles back on, by doing this u reset the position of the needle to read 0 (when I popped the needles off the needles moved and threw them off when i first put them back on). Also make sure u push the needle in all the way or it will not register the readings right. Hope that hels u out a bit.
