Who knows about the JWT drag launch prog.?
663 Views 5 Replies 6 Participants Last post by  nizzan4u2nv
what does it do? and is it for n/a or turbo or both?
and how do i get my ecu reprogrammed from jwt? do i just call them up and send it out?
i think they only have that program for 300zx TT. But i am not sure
You can get it for the se-r. It is armed with a dash switch, and activated with the clutch in. With it on, and the clutch in, you just floor it standing still and it switches to a lower rev limit and may also use a different map (not sure, maybe retard timing?) When you dump the clutch, it switches back to 'regular' rev limit and maps. So basically, you floor it and sidestep the clutch. In a turbo car it will build boost at the line sitting still. It uses the JWT daughterboard, so you can also get the water injection and/or nitrous control features. You can get similar effects with an aftermarket ignition with an adjustable two-step rev limiter with timing retard. You just hook the activation wire to the clutch switch.
andris
Very interesting stuff, sounds like fun...
-Josh
-Josh
It works alot like the MSD 2-step but insted of cutting just the spark(MSD 2-step)the JWT cuts fuel too.
Wow, I think im gonna have to get that once I get the ECU. Do you have to payextra for this program, probably. Same price as turbo programs or as much as nitrous daughterboard. I have just expanded my knowledge.
