I was curious if anyone knew why the G-Force ECU was used for the compcams and Tomei streetcams for the SCC cam shootout a few months ago. I know that it is considered to be just as good as the JWT, but why did they not use the JWT or G-Force on all of the cams tested? It would make sense for consistency, unless there was some type of special programming done? Just out of curiosity......
all the g-force ecu does it mess with the timing and fuel maps. no rev/speed/special programs or anything. it is pretty good if you don't know what you are getting, other than that, go with the jwt, you can upgrade when you decide to go turbo.
