1 - 2 of 2 Posts
Hello guys,
I just replaced my starter today and the car is starting fine now. I had a problem with the engine idle sputtering and found loose bolts around the fuel injectors. I tightened those and now my idle is fine. However when I accelerate and then go to slow down, I put my car in neutral and let go of the gas but my car still stays at the same speed. Almost like I have the gas down still. Sounds maybe like the throttle cable is not adjusted correctly or something. If I take the throttle cable off the piece it connects to close to the TB, the car will idle fine. As soon as I connect it though, and put the gas down it will stay at wot even if I let go of the gas. How tight do I want the cable to be? I loosened it a bit so theres alot of slack but it still catches somewhere? Any suggestions?
1 - 2 of 2 Posts
