Ok here's another one. How about a nx2k '91 strut/spring assembly interchanging with my '92 SE-R? Mainly fronts, will they work? thanks again.
Happiness is not around the corner, it is the corner!
JordanWhiteMusic.com
I would have to make an educated guess and say no, but you should check and comare part #'s between the two cars.
Jordan White (Stormy)
'98 Sentra SE(R)
Hotshot G3 Header, Hotshot CAI, JWT s4 Cams, KYB AGXs, Eibach Sportlines, Courtesy F&R STB's, ES Mounts, MOMO Shifter, Nis-Knacks chrome projector headlights and clear corners, 205/50/15 Pirelli P700Z's on SE-R wheels, 205/40/17 Kuhmos on 17" Borbet Type S's for the summer
15.454 @ 88mph at Englishtown, NJ - with the $hitty stock cams, 14's this season
They will, but the spring rate for NXs is higher than for an SE-R because of the added weight of an NX. I know the geometry and fitment of the assembly is the same across all B13 models.
Paul
'92 NX2000 w/ mods
<font face="Verdana, Arial" size="2">Originally posted by norurb:
Here is a comparrison of springs!
NX2000 Sentra SE-R
Springs 170 lb 160 lb
NX springs are 10mm longer than the Sentra SE-R springs.
Louis
