Ok I want to buy a set of the zex/comp cams. The set is the Stage 2 (part# is CCA-58200) and on the website it says you need aftermarket springs but, on The Great Cam List (http://web.utk.edu/~cjohns32/camlist.htm) it says you can use it with stock valve train.
Do I need valve springs?????
