Wassup guys....Just finished installing my Zex kit! Took about 4.5 hours but that was with me and my buddy taking our time...Cool thing though is we did a kick ass job..the install is so stealth and clean...if you were to look into the engine bay you wouldn't be able to tell shiet! (Just gotta paint that purple brain box black) Install was real straight foward and easy...3 wires, (tps,power,ground) fuel regulator hoses, and the nitrous line. Oh yeah and the switch..he,he,....but the only sad part is for the last 3 months it hasn't rained here in N. Cali..but for some reason....5 minutes before I got done with the install....BAM!!!! It starts raining...so hopefully it lets off by tonight and I can tell you guys how it does....wish me luck! Oh one thing though..the Zex kit activates at WOT..but since it takes the reading off the TPS...the TPS has to hit the activation point of 4.2 Volts at WOT but for some reason my TPS would not register high enough...even with adjusting the TPS it still wouldn't reach that point...but I did modify my tps...so that I could make the proper adjustment...but unfortunetly my car idles a tad bit higher than before...(at about 1,100) hopefully I can get that down somehow..(idle adjustment screw is pretty much closed) But yeah I'll be sure to let you guys know how things are going!
Irwin 96 200sx SE-R (stock)
