Sorry they took so long to design -- I have been very busy over the past several months.
http://www.crank-scrapers.com/prod01.html Scroll down to Datsun/Nissan for extensive description and more pics.
The website home page has some info on this: http://www.crank-scrapers.comiNGEN said:Something I never heard of...a Crank Scraper & Windage Tray. Can someone post a link to info about purpose/application?
bigtoe said:Very Well Done Kevin.
I have e-mailed you on the site for more information.
Is this designed for the 8 as well as the 4 counterweight crankshafts?
It passes through the offset ovoid holes provided for this reason as well as the reliefs for the main cap bolts and the perimeter of the lower (windage) tray.Geo said:Uh, how are you going to get the dripping oil back to the pan?
There is still plenty of oil that is ejected from the rod journals that lands on the underside of the pistons (I have not looked to see if the SR20 has dedicated jets for this as well).downunderNX said:this can be thought of in two ways, there is a reason why engines have oil splashing, it is for the splash lubrication of the undersides of your pistons, with a crank scraper you are taking away the only source of lubrication for some components
Ninety-Nine SE-L said:I'm still not understanding this exactly. Speaking of the mods that reduce the rotational mass of the crank:
Lightweight Underdrive pulley is good for about 3-4hp, I would say
Flywheel, I would assume is a little more due to the reduced mass at a further radius from the center of rotation.
Lightweight crank, is only about 3hp or so due to the fact that all the mass is concentrated in a much smaller radius.
So anyway, how would scraping off a little excess oil produce any readable gains?
I agree with the piston lubrication, not all SR20s came w/ piston oil squirters, particularly the USDM engines. Even though you say it is enough, I'm still more concerned about proper engine lubrication than gaining 1 horse from a mod that would prolly take me half a day to install.
Correct me if I have ventured too far away from the apple tree.
The 1.6 pushrod engine in my 1967 Datsun Roadster (SPL311) had a windage tray. I was impressed.Kevin Johnson said:Older Datsun/Nissan engine designs did not have as much attention to windage control but in designs starting from the mid to late 1980s one can see this trend emerge strongly.
Slartibartfast said:The 1.6 pushrod engine in my 1967 Datsun Roadster (SPL311) had a windage tray. I was impressed.
bigtoe said:Think of it like this;
Stand in a pool with you hand facing front and the palm facing down, now quickly pull yor hand to your hip, throught the water it's harder and slows down right?
Same thing in the crankcase. The oil moves and does come into contact with the counterweights and rods. The windage tray also helps to keep the oil at a consistent level to prevent surge etc.
The oil scraper is an old American V8 trick.
It reduces inertia by wiping excess mass, oil, off the crank, it also reduces windage because the crank does a good job of atomising the oil it throws off. So if you can remove it by wiping it off, then it helps the situation.......big time.
This is not a mod for the bolt on guys.
Every little bit counts and this is truly intended for the racer types.
As far as piston oiling from oil thrown from the crank.............not realy.
The rod journals traverse a sector in their path that takes them almost into the bore with the piston at TDC. The oil leaving the rod journal is slung upwards to the bore, more than sufficient oil.
You also have a thrust face lubrication port in the rod that keeps the bore wall lubricated. Also the Oil control ring pack takes oil into the underside of the piston where it can drain to the wrist pin and the eye at the top of the rod.
Nissan did not intend for a random uncontrolled "windage" to lubricate the pistons or bore.
Again, good product. I want one for my Dry Sump system, I can do with the 1hp gain.
Peanuthead said:My father (when he was a very young man, and still is, only 47 this year) had a top notch engine builder show him what a crank scrapper can do on a dyno. Back to back runs, one without and then one with a crank scrapper, and the second run netted a 12hp gain. I won't ever forget that story.
Now I'm not saying that you will get that, but they do work. NASCAR uses them I believe.
Mine's shipping tomorrowlucino vzr said:when is this thing will be available? and how much are we talking about?
I was reading about the hassle you got at the border -- I will send you one for no charge (need a mailing address in Canada). Good luck in your classes as well.FastNX said:Does it only scrape the end of the counterweight, or the sides as well? Reason I'm asking is I took some material off my crank and the shape of the counterweights are ever so slightly sifferent from stock.
