Q45 TB TPS install
7K views 15 replies 4 participants last post by  NX$paniard
#1 ·
Okay i got an o2 induction with a q45 and im having problems wiring in the tps. Starts up good and takes off to 3k then to 5k in neutral so that points to the tps. I got a tps plug off a q30 and it plugs in and everything now I just need to know how to splice the wires.
TIA
Alex
#4 ·
its into a b13. The plug I have doesnt have red white and black. Thats why im looking for answers from what i have read and heard the middle is usually the signal and the 2 outside ones you have to figure out.
#6 ·
tried that and it doesnt seem to like me. White is the middle one on the b13 plug and the black and red ones are the outside ones. I tried splicing the white into the middle one and the same with the outside ones and no go.
#8 ·
Okay when using a dvm what should i be looking for? I feel like a noob with this stuff but this q45 stuff is unique. I already cut the old tps off so there is no turning back now( i could get one from the junkyard if needed) but i should just be able to splice the wires right in.
#9 · (Edited)
the Q45 TPS IS NOT UNIQUE
It works the exact same way as any other nissan TPS
Theres a Ground----meter will read 0v or close to it
Theres a Signal----meter will read 0-5V depending how much the throttle is open
and Theres a power wire----meter will read 12V.
Theres no mistaking one for the other. If you hook it up backwards itll run liek total ****. Just like hooking up a MAF backwards.
Also which connector are you using? If youre trying to wire into the small black one on the TPS its not gonna work. That is a switching circuit for the cruise control IIRC you need to wire into the pigtail coming out of the TPS box that has red/white/black wires and uses the same connector as many common Nissan 02 sensors....
#10 ·
Theres no mistaking one for the other. If you hook it up backwards itll run liek total sh*t. Just like hooking up a MAF backwards.
BAM there is the info I need, I was trying to do the one on the black tps itself. I thought the other one was for the autos. Your the man and thanks luis for helping me as well. I will try it now and see what happens.
#16 ·
why are you soldering it in? You can just get a connector from various O2 sensors and crimp it in and have it done right?
From what youre saying it sounds like your soldering the wires into the pigtail connector...thats a big no no, but whatever.
****, dont thank Luis....he's been e-mailing me to help fix this problem the whoel time :D :rofl:
